ACT Sensor
Old May 15, 2007 | 08:36 PM
kjspylite's Avatar
kjspylite
ACT Sensor
I've had a problem with my '90 Inline 6 F-150 Stalling. It will run for a few minutes then idle rough and eventually stall. It will always restart, but requires a lot of cranking. I ran the codes from a self test and found that the ACT Sensor was running out of the self test range of 0.3 to 3.7 volts. Is it possible that the ACT Sensor is causing my truck to stall?
Old May 15, 2007 | 09:48 PM
DJdemon6696's Avatar
DJdemon6696
see if tthis helps
http://www.fordfuelinjection.com/?p=29
Old May 15, 2007 | 10:22 PM
kjspylite's Avatar
kjspylite
Thanks...I'll try to test the sensor tomorrow after work and let you know if that works.
Old May 16, 2007 | 12:48 PM
DJdemon6696
ok no problem, letme know
Old May 17, 2007 | 07:58 AM
kjspylite's Avatar
kjspylite
doesn't seem to be the ACT Sensor. I pulled codes again and was given 67 for KOEO and 13 and 24. The 67 is "neutral safety circuit failure". I'm not sure what this is. if this piece were defective, could it be making me stall?
