Rusted body sections need addressing
Old May 15, 2007 | 01:56 PM
ejolliffe's Avatar
ejolliffe
I have a '75 Ford F250 2WD. There are the normal areas of rust/rot on and in the wheel wells, the backside below the tailgate on corners, and near the front of the bed on the bottom corners. The worst spot is the rear below the tailagate. What would be least expensive?...
  1. Finding a replacement bed
  2. Buying repair panels and cut out rusted sections and weld in repair panels?
  3. Fabricate pieces from sheet metal and weld in?
Cost is an issue here, however I would like it done as nice as possible. Any help would be greatly appreciated...
PS- I was told to post this in this section, I apologize for the dual posts from the other forum! =)
Old May 15, 2007 | 02:57 PM
alz's Avatar
alz
I am doing some rust repair on my truck also. That is a lot of areas to repair just on the bed. Before I would start patching, I would check out the rest of the integrity of the bed. Seems as though you have a lot of small areas. You may be better off finding a clean southern bed.
