what would make these codes
Old May 15, 2007 | 01:00 PM
bigbadwolfe's Avatar
bigbadwolfe
i had a buddy with a snap on scanner check my truck for codes this is what i got
0603
1212
what would throw these codes keep in mind i just did stage 1 diy injectors and the truck still runs funny anyone have any ideas i need help thanks
Old May 15, 2007 | 05:59 PM
Cuda_jim's Avatar
Cuda_jim
Is the Check engine light illuminated?
Don't worry about this one. It's from disconnecting the battery.
P0603
Internal Control Module KAM (Keep Alive Memory) Error
These need to be looked into and can make your truck "run funny" if it's going bad.
P1212 {2}
ICP (Injection Control Pressure) Higher That Expected KOEO
P1212 {1} {3}
ICP Voltage Not At Expected Level
{1}—MIL lit when fault is present.
{2}—1997 models.
{3}—1998–2001 models.
Old May 15, 2007 | 11:35 PM
bigbadwolfe
how can i fix this a new ICP these ICPs can be rebuilt right
Old May 16, 2007 | 05:45 AM
Cuda_jim's Avatar
Cuda_jim
It's a sensor located on the driverside head towards the front.
https://www.ford-trucks.com/forums/a...tid=3076&stc=1
Old May 16, 2007 | 09:25 AM
bigbadwolfe
would this make the truck smoke too
Old May 17, 2007 | 03:51 PM
bigbadwolfe
anyone anyone help
