1978 - 1996 Big Bronco
cruise control
Old Oct 10, 2000 | 07:59 AM
AlM's Avatar
AlM
cruise control
Old Oct 18, 2000 | 03:59 AM
lvsnarf's Avatar
lvsnarf
cruise control
I have a 1979 bronco w\cruise control.
Does anyone know how this works or where it hooks up to?
It has never worked.
Old Oct 19, 2000 | 05:01 PM
RRL78's Avatar
RRL78
cruise control
Hey Ivsnarf, tell me a little more about how your cruise control is set up. I have a 1978 Bronco with cruise control and its like this: The electronic regulator is mounted on the side of the fuse box. I have a round servo under the hood mounted to the firewall next to the master cylinder, which has a chain connected to the throttle linkage. I have the engagement switch on the turn signal lever. I have a disengagement switch mounted on the brake peddle. I Have a road speed pick-up mounted near the rear drive shaft, and magnets taped to the drive shaft to line up with the road speed pick-up. I have the original booklet from ford when it was installed. If you need anymore info just keep posting and i'll try to help anyway possible. Oh, yeah. after tonight, i want be able to post anything untill next saturday 10/28/00. I really hope too help. Rob
