1978 - 1996 Big Bronco
Front End Problem
Old Oct 25, 2000 | 12:32 PM
agillings's Avatar
agillings
Front End Problem
I am restoring from the frame up a 1982 F150 Flairside. The truck is down to the frame I just got finished with the front end. I replaced all bushings and ball Joints. After I replaced the right side ball joints I can bearly turn the the to the left and right.The left side is ok. Any thoughts??
Old Oct 25, 2000 | 02:19 PM
AlM's Avatar
AlM
Front End Problem
only a guess...tie rod length?...or, are the ball joint bolt holes out of round from drilling or orig. loose rivets?...good luck, Al
Old Oct 27, 2000 | 08:29 PM
jopey's Avatar
jopey
Front End Problem
