Sponsored by: Real Truck
Leveling kit install question
Old May 14, 2007 | 08:21 PM
97_Ex's Avatar
97_Ex
I have installed several kits before but have recently lost access to a lift. Has anyone installed a leveling kit on a 05 and up SD with a floor jack? How much of a pain is it? Thanks!
Old May 14, 2007 | 08:36 PM
high ho silver's Avatar
high ho silver
05 and up are pretty simple. You just have to add a dougnut shaped spacer to the bottom of the coil springs. I on the other hand have leaf springs and I did mine with 2 floor jacks and a come-a-long.
Old May 14, 2007 | 08:51 PM
97_Ex's Avatar
97_Ex
yeah, I know what you have to do, I did my 2005 but I was just wondering if you could do it with a floor jack
Old May 14, 2007 | 08:56 PM
high ho silver
Yes you can!!!
Old May 14, 2007 | 08:59 PM
carls 250's Avatar
carls 250
yes I just done my 06 SD on sunday using stands wasn't to painful & I did it whith out taking the tires off.The blocks I used I had to grind the edge alittle to fit flat.
Old May 14, 2007 | 11:55 PM
schmidt64's Avatar
schmidt64
What kind of leveling kit you use? I've seen some that come with a drop bracket for the panhard bar and some that don't, any recommendations?
Old May 15, 2007 | 05:31 AM
carls 250's Avatar
carls 250
got mine on ebay from summit engineering for 44.95 + shipping item no. 120119354387
Old May 15, 2007 | 09:39 AM
hotroddsl's Avatar
hotroddsl
I put mine on in the driveway with a floor jack took 30 min. per side I recommend you get a set of spring compressers as that made the job a piece of cake!
Old May 16, 2007 | 05:11 PM
River's Avatar
River
i just put in the DR levelling kit (new 2.5" longer coils) 2 weekends ago with a floor jack and 2 jack stands. pretty easy i thought. second one went a lot faster than the first. just be careful when you lower the axel not to tear a brake line. i had to lower it until they were tight on both sides, and squeeze the new coil in, compressed slightly using a ratchet tie (just a little - 3/4" or so). not enough compression to be dangerous and it worked fine.
