back glass seal
Old May 14, 2007 | 08:17 PM
scooter1986's Avatar
scooter1986
back glass seal
i got a new back glass rubber for my 85 from LMC...it's the solid one not the sliding glass...how hard is it gonna be to install this?
Old May 14, 2007 | 09:47 PM
Franklin2's Avatar
Franklin2
Easy. Put a piece of wire or rope in the groove after you put the rubber on the glass, get someone to hold the glass to the outside of the cab. While they are pushing in, you pull the rope or wire out of the groove, and that pulls the rubber over the metal lip to the the inside of the cab.
Old May 15, 2007 | 12:13 AM
Piffery1's Avatar
Piffery1
I've had good success using GOJO waterless hand cleaner as a lubricant both in the groove and on the metal lip. I use some clothesline from WalMart for the rope. It definately speeds up the process if you have a helper.
Old May 15, 2007 | 05:04 AM
srercrcr's Avatar
srercrcr
Take it to an independent auto glass shop where they handle glass all day, they'll pop it in and not too many bucks.
