1990 f150 a/c ??
To do a good conversion:
- Have the remaining R-12 recovered, if necessary.
- Flush the Evaporator and Condenser with solvent and lots of compressed air (lacquer thinner works well) to remove the old oil.
-Drain the old oil from the compressor. "Flush" the compressor with the new oil.
- If you see oily residue on the bottom of the compressor or on the clutch face the compressor is leaking. Shaft seals and body seals are common leak points on that compressor. The shaft seal can be replaced if necessary.
-Replace all of the o-rings on all of the spring lock fittings and the rear of the compressor. It's ~$5 and is cheap insurance against leaks later on. Don't forget the one on the cycling switch.
-Replace the accumulator. This is important!
-Replace the orifice tube. It is either in the Evaporator inlet pipe or integral to the liquid line. (small line from the condenser to the evaporator).
-Install quality STEEL conversion fittings. The cheap aluminum fittings are prone to leaks.
- Add the recommended amount of oil to the system making sure to add about 2 ounces to the compressor. Ester or Double End Capped PAG oil is recommended.
- Evacuate the system with your vacuum pump for 30-45 minutes and make sure it holds 28" of vacuum for 15-30 minutes.
-Start with about 80% of the original R-12 charge amount. Use only virgin R-134a, no sealers or performance boosters. UV dye is a good idea.
-After you get 80% of the original charge amout in, add refrigerant a couple of ounces at a time until the evaporator inlet and outlet are at the same temperature and suction line is cool all the way to the compressor.
-You are "supposed" to add a high pressure cutout switch to a converted system. That's your judgement call.
If you do it this way, you will likely not notice much difference from R-12. These trucks convert really well if you do it right.
A couple of notes:
-You can adjust the cycling switch to bring the low side pressure down a bit for R-134a. Turn the screw clockwise, no more than 1/2 turn.
-At 17 years, your fan clutch is probably weak. This will kill the AC performance at low speeds and cause the high side pressure to be too high.
-The low side pressure is roughly equal to the evaporator temperature. (1500 RPM, Max AC setting, blower on high and doors open)
-Rule of thumb for the high side pressure is about 2.5 times ambient temperature (1500 RPM, Max AC setting, blower on high and doors open).
-Don't be tempted by "conversion kits". The fittings are poor quality and there is nothing else in them that you can't buy separately.
- Use regular cans of refrigerant and a can tap. Cans with a hose attached push air into the system. That little bit of air can make the difference between a system that works and one that works well. Make sure to bleed the air out of your gauge hoses too.
Think about this. If you reseal the system properly and replace the accumulator, you should not have to service it again for many years. The "high" cost of R-12 will be spread over that time and is really not a major expense. R-12 is what the system was designed for and will give the best performance. For $25, you can take an online test to be certified to buy R-12. It is about $8-10 per pound in 30lb containers, the small cans are higher. Just something to consider.
Good Luck
-The problem with the oil is that the R-134 will not carry the old mineral oil through the system, thus starving the compressor for oil.
- There are no compatability issues with the o-rings, they are just 17 years old and cheap to replace in the spring lock fittings that are notorious for leaks.
-When the system is low on charge, air is drawn into the leak by the natural expansion and contraction of the gases left in the system due to temperature. There is also air in the charging hose of each can of R-134a that you used. It only takes a small amount of air to raise the head pressure enough to damage the compressor.
-If you had a leaky tire, I wouldn't expect you to replace the rim, but I would expect you to fix the leak and replace the $1.50 valve stem if it was 17 years old.
- In these trucks, R-134 will certainly cool as well as R-12 IF the job is done right.
I certainly hope that your attitude about the AC doesn't carry over to other maintenence areas. If so, that "excellent condition" truck won't be for long.
I don't like seeing people spend $20-40 to avoid a $200 repair that will now cost them ~$1000. I like making money, but not like that. Think about this; If AC repair could be done that cheaply and be reliable, I would not have a job.
Ok. Since you've dumped the charge, take a few minutes and about $15 to do a few things that will give you a fighting chance.
-Get a set of Spring Lock Coupler tools (loaner from the parts store). Separate all of the fittings and replace the o-rings. Replace the 2 at the rear of the compressor. It's really easy and cheap.
-Get 8-10 ounces of Ester based oil. Remove the compressor and drain the oil out. Add back about 2 ounces of Ester oil. Remove the accumulator and drain all of the oil that you can. Add back about 3 ounces. (You really should replace it, but...). If you have a compressor, blow the oil out of the condenser, evaporator, and lines as much as you can. Add the remaining oil where you can. You want at least 8 ounces of the Ester oil in the system. The old oil just takes up real estste in the system. (You really should flush, but...)
-Replace the orifice tube. The red one is slightly smaller and is said to work a bit better. I personally never saw much difference but maybe bustech81 has. It's also a filter screen and the old one will have some debris in it.
You mention having a vacuum pump. Do you have a gauge set? If not, you can rent\loan from a parts store.
Pull a 29" vacuum on the system for at least an hour. Charge about 80% into the system making sure to bleed the air out of the lines between cans. (Not an issue with a can tap and regular cans). Add more a couple ounces at a time until both evaporator tubes are the same temperature (1500 RPM, Max AC, High Blower, doors open) and the suction line is cool back to the compressor. The high side pressure should be about 2.5 times ambient temp, the low side pressure should be as close to 30 as possible. You can adjust the screw on the cycling switch to tweak it a bit.
If the outlet temperature goes up at idle, your fan clutch is probably bad. It's really common on these trucks.
Although this isn't the greatest way to do it, it's pared down to the bare minimum. You will have a decent chance of the system working good without damage and frequent topping off.
Good Luck
PS. My conscience insists that I say this," You really should do it the way I outlined earlier".
The parts (accumulator, orifice, etc. ) from Auto Zone are fine.
If you have all of that equipment and tools, you are good to go. Here's a list with approxomate prices.:
Accumulator- ~$28.99 9(AZ, part #4218)
Brass retrofit fittings- ~$10 (NAPA) The aluminum Interdynamics fittings are very prone to leaking.
Oring kit- $8.99 (AZ, part # MT2526)
Ester oil- ~$6
orifice-~$3
can tap- $5.99 (AZ)
Spring lock tools- $5-20 depending on which ones you buy. The clamshell type work best. AZ may even loan them.
You'll need refrigerant, of course. Get the pure R-134a, no sealers or additives. Get one can with UV dye, I think it's $1 more per can. That way, if you ever have a leak, you can find it easily with a black light.
You can do the whole job for less than $100 and, barring a compressor leak or blown hose, it should last the life of the truck. The only other expense may be a fan clutch, ~$60. The parts you are replacing are wear items, so used stuff isn't a good idea. Used hoses are a judgement call. I think the later condenser for R134 will bolt right in. Used is ok as long as there is some charge left in the doner truck and it's not physically damaged.
Written down, it looks like a lot of work, but it's really not. You'll see once you get into it. Doing it this way, you should be able to get vent temps in the high 30s-low 40s.
That Harbor Freight gauge set is a good deal for a DIYer. If you look at their site, they also have a flush gun for about $25 that works really good.
Since you asked: I was a Ford Master Tech until 2001. I changed careers and went into Information Technology 7 years ago. I have a part time business doing MVAC service and electrical work on collector cars, bikes, ATVs, etc. I got fed up with working on cars, but I still can't keep my hands clean
Good Luck, and if you need anything just yell.
