Sponsored by: Real Truck
electrical problem
Old May 13, 2007 | 11:09 AM
MikeGrz's Avatar
MikeGrz
electrical problem
99 F250 V-10 has had 2 alternators replacements, the alternator light is on, the gauge goes up & down and the truck idle also goes up & down, also saw that the lights have a slight barely detectable flicker/pulse
any help appreciated, thank you
Old May 14, 2007 | 07:14 PM
ReAX's Avatar
ReAX
Did the alternators test bad?
the flicter could be just one of the three fields failing, if so you need to try a quality alternator. All three fields are tied together, so if only one fails it's an internal problem.
