Rear access door adjustment
Old May 12, 2007 | 10:15 PM
Buck 1's Avatar
Buck 1
Question Rear access door adjustment
On my '05 F-150 the rear access door behind the passenger door rattles when going over rough roads. How can I adjust it, or does this warrant a trip to the dealer? I would rather do the adjustment myself if someone can explain how to do it. Thanks in advance for your help!
Old May 12, 2007 | 11:21 PM
edgl's Avatar
edgl
Just let the dealer do it. I am sure that they do this all the time.
Old May 13, 2007 | 02:05 PM
cdestuck's Avatar
cdestuck
Have this same problem at times but in my case at least I'm finding the the bottom latch does not always catch. When I close the rear section, I usually grab the door several inches below the latch, and close it firmly. If you then pull back and forth on the door, you should see no movement at the bottom of the door. MIght be your problem also.
Old May 13, 2007 | 10:15 PM
irishammer's Avatar
irishammer
My 04 does the same thing...
