Sponsored by: Kumho
Leaf Spring Bushings
Old May 12, 2007 | 09:26 PM
73strokin's Avatar
73strokin
I just got my Superlift lift kit and am installing it this weekend! When I put the bushings and metal sleeves into the ends of the leaf springs, should I apply some type of grease to all these parts or are they made to work dry? The new bushings seem like more of a plastic material as opposed to the OEM rubber bushings. Does the material make a difference for lubricating?
Old May 12, 2007 | 09:39 PM
75F350's Avatar
75F350
they should be polyurethane, and yes you should apply a little lube to them. Some will actually require it to help with assembly. They will eventually dry out and squeek, but until then they will ride fine with a little dab of grease.
kioolt
Oct 25, 2013 05:12 PM
spinella
Mar 23, 2010 08:42 PM
Christopher2
Nov 13, 2004 07:48 AM
BlueKnight
Dec 19, 2002 01:39 PM
