Gas Tank Install
Started working on putting the 70 Mustang tank into my 52 F1 today, removed one cross support no problem but the other one also is part of the rear leaf spring mounts. If I grind away the rivet on this support will anything happen with the leaf spring? I know I'll put a grade 8 bolt in where I grind the rivet away but is there anything else I need to know before I do this?
Thanks in advance for your help.
