Heads info
Old May 12, 2007 | 05:54 PM
usdart's Avatar
usdart
Heads info
I haven't posted in a while because all my tools were in storage with Atlas Van Lines.
I bought a home and my goods will be delivered on the 21st.
I am very excited to get back to work on my truck.
Questions;
I can get a set of 1990 heads off a 302 engine, will they interchange on my 1970 302 cid?
How about the exhaust manifolds.
All this is off a 1990 Bronco which I can get for free. The engine is 'supposedly' good, just the transfer case is toast. The guy towed it with the case in gear.
Reason I ask is I have a 'miss' I am guessing is a burnt valve. I replaced the carb and dist and wires and I have an inconsistent 'pop' about every 15 seconds at idle. Idle is rough, but at 15 mph it clears up and runs great.
The engine has not used any oil yet so I figure it is worth a lil work to get it right.
Thanks for listening; Dave
Old May 13, 2007 | 10:08 AM
TigerDan's Avatar
TigerDan
Dave, the later heads will bolt right up and either head/manifold comb will interchange, as there were virtually no significant changes made to exhaust manifold bolt patterns over the years.
That said, I'm not sure I agree with your diagnosis. A burnt valve will cause a loss of compression in that cylinder (and therefore a miss) that won't improve. I'd do a compression check, and have a look at the plugs while you're at it. It almost sounds like a partially fouled plug.
Old May 13, 2007 | 02:14 PM
usdart's Avatar
usdart
Plugs?
Thanks, I am going nuts on this thing!
New Carb and new point distributor, Just changed the plugs today and all 8 of the old ones looked GREAT. Using AC 25 peanut plugs, same as came out. All 8 plugs were a little on the white side but not too much.
Is it possible that the fuel filter on the pump is clogged? I thought not since it runs great after 15 mph. I was thinking if I starved the carb at idle it would get worse on acceleration? I have not changed it yet and it looks OLD.
Timing is strange though, If I advance all the way til it hits the Water outlet it runs best. But, It never 'bumps' the starter (as in too far advanced).
Do you think I could be one tooth off on the dist gear?
Thanks! Dave
Old May 13, 2007 | 09:19 PM
TigerDan's Avatar
TigerDan
That could very well be. Sure seems like it if you can't get any more advance than that. And I'd still change the filter if it's old, but you're correct, a plugged filter would make the engine run worse as RPMs increase and it starves for fuel.
How about the points in that new distributor, are they set correctly? Checked for vacuum leaks around the base of that new carb?
If you have a vacuum gage, hook it up and check the readings and then compare them with the sample readings on this page:
http://www.users.bigpond.com/ergoff/vac1.htm
Another trick is wait till it's pitch dark outside and then start the engine and look under the hood with it idling to see if there's any crossfiring in the plug wires. If there is, you can tell instantly from the pretty light show.
Old May 14, 2007 | 06:16 PM
usdart's Avatar
usdart
Miss
You know I never thought about the points. The distributor was put in new and the cap and rotor also by a Shop. I did not re-check the point gap. Should be about .017 if memory serves me. I will do that before I move the dist around.
I checked for vac leaks, the plug wires are new too.
I learned along time ago "make one change at a time" and check to make sure it still runs.
I'll keep ya posted after I work on it a bit this weekend.
Thank you!
Captn B
Nov 6, 2014 09:35 AM
Bullitt390
Mar 11, 2014 01:45 AM
chewedtoothpick
Aug 17, 2013 07:41 PM
TheDesertRat
Oct 22, 2009 10:55 PM
fordtrucksj
1966 - 1977 Early Broncos
Apr 21, 2008 11:35 PM
