Maximum battery physical dimensions.
Old May 11, 2007 | 09:52 PM
Xyzzy's Avatar
Xyzzy
07 F150 XL
The current battery (Motorcraft BXT-59) seems pretty small, physically. The box it sits in has a large gap all around the battery. The top says 540CCA, which seems kind of wimpy to me.
I was wondering what the largest size battery I can fit in, physically. I have been reading about different "group sizes" but I am more confused now than when I started. I am not planning to replace it soon, but the info would be nice to know down the road.
The truck did sit on the lot for 6 months with (I assume) no driving, since I got it with 6 miles, so I have no idea if it has been damaged. So far it works fine although I think it should start up more forcefully. My wife's Escape with the original (very small) OEM battery seems "snappier" when starting. I have no idea what size her battery is.
Thanks!
Old May 11, 2007 | 09:59 PM
Franklin2's Avatar
Franklin2
If you go to the parts store, I see they offer a 850 CCA battery for your truck. I don't think physical size has much to do with it. I went to www.partsamerica.com and plugged in your truck and they had a 850 and a 675 available. I did plug in a 5.4 v8.
Old Jun 18, 2007 | 10:34 PM
Xyzzy's Avatar
Xyzzy
I have no idea if this will help anyone, but here goes:
Group 59:
Group 65:
The larger battery also has the advantage of having removable cell caps, so you can add water if necessary. Some people aren't into that but I am.
From the reading I have done, Interstate is the ticket for batteries. I think Motorcraft batteries are made by the same parent company. In the same size the Motorcraft batteries are rated a bit lower.
Old Jun 18, 2007 | 11:27 PM
Mil1ion's Avatar
Mil1ion
That size battery goes on Motocycles here in Canada ...except the west coast
I have a 1000 CCA battery and 2 other 850's
Exide makes a lot of the batteries these days.
Old Jun 18, 2007 | 11:39 PM
Xyzzy's Avatar
Xyzzy
I think Johnson Controls makes Interstate and Motorcraft. I do know that Sears Die-Hard batteries are pieces of junk.
I used to live up north, which is why the Group 59 battery struck me as a bit inadequate. But down here I bet it would have been fine.
I bet Ford sends different batteries to different regions. Like my F150 doesn't have an engine oil heater thingie and I bet yours does.
I sold the OEM battery for $40 so my out of pocket was $60. The dealer wanted a lot more for some upgrade package that included a more powerful alternator. I figured it would be cheaper to do it myself, and I can't picture needing a more powerful alternator with as little as I have running.
Old Jun 27, 2007 | 12:57 AM
RadarRick's Avatar
RadarRick
Can you fit 'TWO' optima yellow top batteries in the space as the orginal 2007 F150 5.4 OEM location?
I am considering a dual battery system but don't know where the second battery can fit. The optima yellow top appears to be a physically smaller dimension battery.
Any one have a dual battery set up in a 2004 plus 5.4? If so where did you fit the second battery? Photos would be helpful.
Thanks,
RadarRick
sandrew1202
25
Feb 16, 2018 12:51 PM
cody311
Dec 5, 2016 12:21 PM
Wealthk1
Oct 23, 2016 05:55 PM
PROSTOCK
May 9, 2016 06:06 AM
fordtrucksforever
Jan 6, 2016 09:47 AM
