trash block or rebuild???
Old May 11, 2007 | 08:58 PM
DL70f100's Avatar
DL70f100
Question trash block or rebuild???
Im only 23, so exuse me if I ask something that should be a no brainer:
I pulled my 302 out of my 70 f100. When I pulled the oil pan I found two shattered connecting rods... They were still connected to the pistons... just broke at the bottom... The truck was sitting for 2 years and I just cranked it after replacing some upper engine parts.. It ran until it was parked... It looks like everything is still okay just luck that nothing else got hit... should I just replace the connecting rods or start from scratch.. I am eventually getting a bigger engine, but for now I am looking for a cheap way to get it running until I can get money for a 351... piston walls are all nice and smooth and everything seems to be intact... I am just looking for advise from a few pro's.....
My truck is a 1970 but the grill is the 71 style... It came of the line in November.. So when I look at certain engine parts it asks 70 or 71... Does it matter??? I thought the only difference was the grill..
Old May 11, 2007 | 09:52 PM
dslmechanic's Avatar
dslmechanic
If everthing looks good I would just replace the rods especially if you are just looking to get by.. Kevin
Old May 11, 2007 | 10:28 PM
Redcat Diesel's Avatar
Redcat Diesel
With 2 broken connecting rods and limited experience I'd suggest you have someone with a background in engine work take a look at it.I've seen con rods fail and they usually cause some serious damage.The cylinder walls may be okay but what about the crankshaft and other parts?
Old May 12, 2007 | 02:18 PM
boggerted's Avatar
boggerted
I wou8ld check all the crank journals, but if you are planning on replacing the engine anyway, i think you could get by with just new con rods.
Old May 15, 2007 | 12:06 PM
mcdobson's Avatar
mcdobson
You need to figure out why the rods broke. No sence in replacing the rods if you have a crack some place thats going to hydraulic the cylinders and bend rods again.
Mike.
Old May 15, 2007 | 06:58 PM
DL70f100's Avatar
DL70f100
thanks for all the advice..... the guy I bought my truck from let some kid drive it and he drove it out of oil.. they parked it knocking real bad.. so after two years of sitting I just threw some new rods and gaskets not thinkink it was a big knock and started it...
