when to re-gear ???
Old May 11, 2007 | 08:14 PM
mattd17's Avatar
mattd17
when to re-gear ???
hi all, for those of you running a 6" lift with 35's, did you re-gear, or does the power plant push them ok with the stock gears? i wont be towing much, (if at all.... i just really like the looks!!!) but i dont want it to turn into a gutless wonder. i do have the edge with magnaflow siso exhaust, so my getting a little better power over stock. im just not sure if it will run good, or if i will be needing bigger gears soon down the road. thanks a bunch !!!
Old May 11, 2007 | 09:10 PM
deisele75's Avatar
deisele75
What gears do you have right now?
Do you have limited slip?
Old May 11, 2007 | 10:01 PM
VFR_Man's Avatar
VFR_Man
Unless you think it's a rocket ship now, I can just about guarantee you'll think it's a dog after going from 31-32" tires up to 35's. That's a 10%+ change, definitely noticeable.
Old May 11, 2007 | 10:06 PM
xplict's Avatar
xplict
I have 35's with factory 4.10's and its a bit of a difference but not as much as i thought it would be. I will eventually change to 4.56's or 4.88's.
I have K&N intake with flowmaster DIDO exhaust. The bigger tires slow it down a bit, but the truck still moves GOOD!
Old May 11, 2007 | 10:41 PM
gui88ford's Avatar
gui88ford
for every inch you go up in size you lose a tenth off your gear.....
example:
31" tires to 35" tires.....= +4
stock 3.55 gears now are in effect 3.15 gears so you need to go up a tenth in gear to keep you stock for every inch you gain in size to keep the stock gear...
