Oil
Old May 11, 2007 | 04:36 PM
ola1234's Avatar
ola1234
Question Oil
Anyone who can list what kind of oil is being used on my 1991 F-250 7,3D, E4OD?
Engine-
Powersteering-
Brake fluid-
Transmission-
Transfercase-
Differential-
Cooling-liquid-
And should I use any additives at some of these positions?
Old May 13, 2007 | 05:05 PM
Winger235's Avatar
Winger235
Engine-
Powersteering-
Brake fluid-
Transmission-
Transfercase-
Differential-
Cooling-liquid-
Engine = 15W-40
Powersteering = Powersteeing fluid or ATF
Brake Fluid = DOT-3
Transmission = Dexron3/Mercon
Transfer Case = Dexron3/Mercon
Differential = 75W-90
Coolant = 50/50 with anti-cavitation additive.
No additives clean oil is better. I use synthetics myself have had great luck with the stuff.
Old May 13, 2007 | 05:50 PM
2jhanna's Avatar
2jhanna
power steering should be "type f" atf, if i remember correctly.
don't know how much difference it makes, but i think that is what's spec'd.
