charging problems?
Old May 11, 2007 | 10:32 AM
MikeGrz's Avatar
MikeGrz
charging problems?
A 99 F250 V10 has had the alternator changed twice, problem went away for 2 weeks and has returned
the volt light is on, volt meter goes up & down, idle goes up & down,
and
at idle there is a flicker-surge in the the lighting
any help will be appreciated
Old May 11, 2007 | 10:01 PM
Franklin2's Avatar
Franklin2
I would take the alternator off one more time and get it checked. If it's bad, then we have to decide is the truck causing it or is it a crappy rebuilt alternator. Sad to say, it could be the 2nd senario happening.
They also have a caution with this alternator. If the battery is not fully charged when you put the new alternator in, it could burn up the new alternator.
Old Jun 1, 2007 | 09:34 PM
heatmon's Avatar
heatmon
Lightbulb Charging problem
Right- new alternator + bad battery = bad alternator!
