Brake failure post mortem
Old May 10, 2007 | 10:00 PM
Corey872's Avatar
Corey872
Had a chance to tear down my front brakes the other day. Regular readers will remember my post last week about the drivers front brake locking up on my cross-town drive which resulted in enough heat to melt the plastic "dog bowl" hubcap off the wheel.
I tore down the caliper and found out that one of the pistons had a missing rubber dust boot. Didn't look like it was melted or eroded, it was just gone like someone had ripped it off. The left side (arrow) is the problem. The missing boot let water in which caused rust around the piston.
The rust lodged between the plastic (yes, plastic!) piston and the cylinder which locked everything up good.
You can see the scores on the piston.
A couple of revelations about the calipers...no auto parts store in town had them in stock (this is a three year old "most popular selling truck in America") and no one stocks brake parts! Also, no rebuild kits...it's the complete caliper or nothing! The other thing that blew me away was the plastic pistons...of all places to save a pound or two...Next time you are hauling down that 9000 pound load, think of those little chunks of plastic at the end of the brake pedal!
Old May 10, 2007 | 11:50 PM
edgl's Avatar
edgl
Can't you upgrade to a steel piston? You pay so much money for a truck, and they give you plastic brake pistons. If you are hauling something, you have to use more braking, which will cause these plastic pistons to get very hot.
Old May 11, 2007 | 12:03 PM
Corey872's Avatar
Corey872
I noticed that some of the calipers for the '04 heritage had a 'heavy duty steel piston' option, but that didn't appear to be the case with the 04-up new body.
On the plus side, my wheel/brake combo got hot enough to melt the hubcap off, the pistons survived with only a little flaking of the plastic on the pad mating surface. The parts list I saw said 'phenolic piston' which is probably glass fiber reinforced phenolic. That is a thermosetting plastic which means once it is molded, it won't 'melt', but it still blew me away to see the two lumps of plastic!
Old May 11, 2007 | 01:54 PM
schneidz's Avatar
schneidz
they are canvas/linen phenolic pistons, this material is used to move trains and its plenty strong for what they are being used for and i don't think it was a cost savings measure in the least bit but instead a superior engineered material used in this circumstance.
Old May 11, 2007 | 02:37 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
phenolic = wood
the Navy uses it as a bearing on the propulsion shafts that are subject to seawater. the material is very durable
Old May 11, 2007 | 08:29 PM
Ferguson65's Avatar
Ferguson65
This isn't the fist time Ford has used the phenolic pistions. Don't know the history on your truck, or miles, but I'd bet that dust boot got in someone's way when doing a brake job at some point and it just got tossed. There are some very bad dealer "techs", and I used to work for a dealer that had quite a few of these hackers.
Old May 12, 2007 | 10:18 AM
Ryan50hrl's Avatar
Ryan50hrl
my 95 had plastic pistons.....and i'm guessing no one carries calipers because for the most part, these trucks are too new to need many major repairs yet.....
Old May 12, 2007 | 11:54 AM
MeanGene1's Avatar
MeanGene1
Here is some info on "plastic pistons"
http://www.vyncolit.com/EN/6News/Piston%20V1_03.pdf
BiGGreen350
Ford Truck Parts for Sale
37
Oct 27, 2014 02:25 PM
fordktpjoe
30
Jan 27, 2011 11:46 PM
66fdtrucknut
Maryland Chapter
Aug 26, 2010 07:47 PM
black58
15
Apr 5, 2009 08:31 PM
fordboy_52
Kansas Chapter
16
Jan 10, 2008 09:54 PM
