how to fix cab corners on an 87 f250 ext cab what is the best way to fix them and also how much should a paint job cost that is two tone silver and dark blue?
The cost of a paint job can cover a huge range from $300ish to $9000ish. All depends on the shop, the amount of prepwork, the warranty, the color choices, and type of paint.
Shooting a car isn't anywhere near as expensive as the labor-intensive prep-work.
Cab corners aren't difficult to fix... just time consuming.
If you have a replacement corner, it's a matter of cutting the old one out slightly undersized, making lips between the old and new, and welding them together.
If the corner isn't too bad, sometimes one can use steel sheet and weld it around for a nice homemade patch. All depends how bad the corner is to start with.
the cab corner is pretty bad i dont know who to trust to fix it the only two i trusted to work on it one camited suicide and the other moved away so i dont know whether to fix it myself or try to find someone else to do it
