Reverse Sensing System Problem
Old May 10, 2007 | 11:34 AM
clarkerm's Avatar
clarkerm
Problem started (probably coincidental) after replacing the multi-function switch on my 2002 Excursion. The dash switch "off" indicator remained light from the moment the vehicle was put in reverse. I noticed the reverse lamp was not functioning and replaced. Now the RSS will function properly as long as I apply the brake, but as soon I release the brake the RSS "off" indicator illuminates and the RSS system is non-functional and subsequent applications of the brake toggles the RSS system. Any suggestions?
Old May 10, 2007 | 01:54 PM
Franklin2's Avatar
Franklin2
Why did you replace the multi-function switch?
Old May 10, 2007 | 02:53 PM
clarkerm's Avatar
clarkerm
The flasher relay was chattering due to a problem in the multi-function switch. Oddly enough, this relay would also operate normally when applying the brake.
Old May 10, 2007 | 05:30 PM
Franklin2's Avatar
Franklin2
Have you replaced the engine in the past? I am thinking grounding problems.
Old May 11, 2007 | 11:05 AM
clarkerm's Avatar
clarkerm
No I haven't. But the vehicle was a exec lease return when I purchased in 2003.
