How do you test the CDR?
Old May 10, 2007 | 08:13 AM
ndzner's Avatar
ndzner
How do you test the CDR to check that it is working correctly?
Old May 10, 2007 | 08:24 AM
PLC7.3's Avatar
PLC7.3
Do you know when to service your CDR valve?
All 6.9L and 7.3L diesel engines are equipped with a CDR (Crankcase Depression Regulator) valve. Even the new 7.3L Power Stroke is also equipped with the same valve. The CDR valve is one of the leading causes of head gasket failure in these engines. The CDR valve is responsible for controlling the pressure/vacuum in the engine crankcase, and seperating the oil mist from the air and returning the oil to the crankcase. The CDR valve should be serviced every second oil change or when signs listed below are seen.
When the CDR valve is not properly serviced, engine oil enters the air intake and is drawn into the engine. The diesel engine will burn this oil as fuel, however, it is heavier and thicker than diesel fuel and, having greater BTU output, causes excessive heat in the cylinder. Due to the intake manifold design, most of the oil will migrate to #7 and #8 cylinders; the last two cylinders in the rear by the firewall. The increased temperature here will cause the cylinder head to lift off the gasket and allow water or oil to leak out the back of the cylinder head where it meets the block.
To check your CDR valve, remove the air cleaner hold down bolt and inspect it. If the bolt is covered with engine oil mist, it's time to service your CDR valve! Ford calls this item a "Adapter assembly for Crankcase Ventilation" Part number E3TZ-6A665-A or IH part #1805319C1
To service the CDR wash with a solvent, allow to dry, do not use compressed air to dry. There is a small hole in the CDR back cover, ensure it is clean and open. If black chunks of rubber are visible in the intake, on the screen then the rubber membrane has disintegrated, replace the CDR.
Old May 11, 2007 | 03:01 AM
LaPuente's Avatar
LaPuente
Question: Can i replace the CDR with a tube, connected in a Oilcatchtank?
Like in many other engines in the world.
I think, this can be the best thing, because no more oil will going into the cylinders and effects overburning.
Next time I will replace my Headgaskets, because of this typical Ford-Firework....I need 1 Liter Oil in 1000 km, the most of them bubbles out on the firewallside of the heads.
Old May 11, 2007 | 07:21 AM
PLC7.3's Avatar
PLC7.3
LaPuenta....
The early 6.9s are known for head gasket problems at the rear of the engine......
A road draft tube can be built, fancy wording for crankcase vent of the old days. You will get oil odour and smoke when stopped, at a light let's say. Personally I think they are filthy and doing it the righ way is best....... When you do the heads, add several more holes to the baffle on the new valley pan.........
Old May 26, 2007 | 05:51 AM
F250FarmBoy's Avatar
F250FarmBoy
This is dumb, but where is the CDR located?
Old May 26, 2007 | 08:18 AM
speedrdr's Avatar
speedrdr
it's on the back of the intake opening, held on by two 1/2 inch bolts.
speedrdr
Old May 26, 2007 | 01:26 PM
F250FarmBoy
Ok i know what it is now. Thanks speed
