Aerostar Ford Aerostar
Name this problem ?
Old May 10, 2007 | 03:50 AM
JTHill24's Avatar
JTHill24
Name this problem ?
91 3.0
Starts great, Idles fine, But when you step on the gas to rev it, it Stumbles, Skips, and Loses power.
Plugs and wires have been changed. What would be some things to check or Clean?
Thanks,
JaY
Old May 10, 2007 | 04:56 AM
Pablo-UA's Avatar
Pablo-UA
Many hypotesas from low fuel pressure to clogged cat.
As I've understood, there are no codes....
Old May 10, 2007 | 04:58 AM
streethealer's Avatar
streethealer
Timing off or a clogged fuel filter maybe?
Old May 10, 2007 | 05:02 AM
Pablo-UA's Avatar
Pablo-UA
May be.... may be clogged fuel filter inside the tank. This problem is more frequent.
Old May 10, 2007 | 05:29 AM
96_4wdr's Avatar
96_4wdr
codes?
cold hot or both?
TPS?
MAF?
idle base timing and advance? worn or damaged dist.
Old May 10, 2007 | 05:36 AM
Pablo-UA's Avatar
Pablo-UA
Bad TPS - rev up with delay.... That is all.
Bad MAF - CE Light and code, wont rev up well.
Old May 10, 2007 | 08:27 PM
Aeroman59's Avatar
Aeroman59
Originally Posted by JTHill24
91 3.0
Thanks,
JaY
Sounds to me like something is causing fuel restriction. Clogged Fuel filter, bad fuel pump, low fuel line pressure or leaking fuel pressure regulator, gummed fuel injectors. Gunged MAF sensor.
What is your MPG on highway?
