1978 - 1996 Big Bronco
1989 Bronco Breaks
Old Jan 31, 2001 | 07:07 PM
joeyv821's Avatar
joeyv821
1989 Bronco Breaks
I have a 1989 Eddie Bauer Bronco, 5.0L V8, I've been having trouble with my brakes, I push lightly on the brakes and it stops so fast, someone told me it had something to do with a VACUME and a tune up would fix it.
I apreciate any help,
Thanks Joey Victorino
Old Feb 1, 2001 | 06:28 AM
AlM's Avatar
AlM
1989 Bronco Breaks
Joey, if it is running ok, then just check your rear brake shoes & fr. pads/rotors for glazing, gunkiness. 2 cans of brake cleaner may help. This is the cheapest & ez'iest check I have for you.
Also, mine grabs tight early in the morning until it burns off the dew.
Old Feb 1, 2001 | 08:24 AM
odinmurphy's Avatar
odinmurphy
1989 Bronco Breaks
If your rear axle seals are bad, you may be leaking 80/90 weight gear lube onto your brakes. I had this happen in my 85 Bronco. My Brakes would lock up I changed the seals and the shoes, never had a problem after that.
Good Luck
Murph
Old Feb 1, 2001 | 06:00 PM
billyb's Avatar
billyb
1989 Bronco Breaks
drake_bartel
15
Mar 27, 2021 01:29 PM
Ross.bunnell
Mar 27, 2016 05:46 PM
nitronigs
Mar 29, 2011 08:01 PM
Bronco916
Sep 17, 2003 02:17 AM
