radio problem
Old May 9, 2007 | 09:36 PM
atillett's Avatar
atillett
radio problem
when i start my truck, every time the radio loses all memory. there was not a radio in it and i installed one with a install kit to all instructions. the truck is a former fire truck and the solinoid on the fender is where they fed the pump and reel. All the wires are on the front post could this be the problem. thank you...
Old May 9, 2007 | 09:45 PM
quicklook2's Avatar
quicklook2
it helps to know what year.
Old May 9, 2007 | 10:06 PM
atillett's Avatar
atillett
1988 f-250 hd 351 4x4
Old May 9, 2007 | 10:39 PM
dverkest's Avatar
dverkest
Obviously the orange “Hot” wire is being switched with the ignition, which should always be hot. Double check you’re wiring harness kit and how you have it hooked up.
<o>> </o>>
<table class="MsoNormalTable" style="" border="0" cellpadding="0"> <tbody><tr style=""> <td colspan="2" style="padding: 0.75pt; background: white none repeat scroll 0% 50%; -moz-background-clip: -moz-initial; -moz-background-origin: -moz-initial; -moz-background-inline-policy: -moz-initial;">
P o w e r<o></o>
</td> </tr> <tr style=""> <td style="padding: 0.75pt;"> Memory (+12v Constant)<o></o>
</td> <td style="padding: 0.75pt;"> <st1:city w:st="on"><st1>Orange</st1></st1:city><o></o>
</td> </tr> <tr style=""> <td style="padding: 0.75pt;"> Ignition (+12v Switched)<o></o>
</td> <td style="padding: 0.75pt;"> Red<o></o>
</td> </tr> <tr style=""> <td style="padding: 0.75pt;"> Ground (-)<o></o>
</td> <td style="padding: 0.75pt;"> Black<o></o>
</td> </tr> <tr style=""> <td style="padding: 0.75pt;"> Illumination<o></o>
</td> <td style="padding: 0.75pt;"> Yellow<o></o>
</td> </tr> <tr style=""> <td style="padding: 0.75pt;"> Phone Mute<o></o>
</td> <td style="padding: 0.75pt;"> Yellow/Black<o></o>
</td> </tr> <tr style=""> <td style="padding: 0.75pt;"> Power Antenna<o></o>
</td> <td style="padding: 0.75pt;"> Blue<o></o>
</td> </tr> <tr style=""> <td colspan="2" style="padding: 0.75pt; background: white none repeat scroll 0% 50%; -moz-background-clip: -moz-initial; -moz-background-origin: -moz-initial; -moz-background-inline-policy: -moz-initial;">
</td> </tr> </tbody></table>
Old May 10, 2007 | 05:52 PM
atillett's Avatar
atillett
I will look into tonight thank you.a allen
Old Apr 1, 2009 | 09:01 PM
atillett's Avatar
atillett
I know this is a really old post, but i think that i might have fixed the problem, by accident, i was looking at the ground wire on the battery and noticed the small wire that goes to the two wires that are in the harness looked bad, well anyways i decided to redo it and make it look better, and discovered that the wires were just twisted together, so i soldered them together and reinstalled them and guess what the radio has not lost memory yet.....I hope that this fixed the problem.......
Old Apr 1, 2009 | 10:46 PM
LCAM-01XA's Avatar
LCAM-01XA
Hey, who knows what wires you fixed, but you fixed it, that's all that matters!
Pmustian
Sep 4, 2014 03:59 PM
SuperSnake
Jan 1, 2007 10:09 AM
hunter_firefighter
Electrical Systems/Wiring
Sep 26, 2005 05:05 PM
65vamonster
Jul 10, 2004 09:42 PM
