f 250 carb problems
Old May 9, 2007 | 08:04 PM
crazyman112222's Avatar
crazyman112222
f 250 carb poping
every time i start my truck it iddles smothly. But when i try to rev it up it starts but then theres a pop in the carb and then it dies and goes down to the idle. what is the poping caused by
Old May 9, 2007 | 10:43 PM
fmc400's Avatar
fmc400
MSEE
Popping is caused by a lean condition or the timing being off (for the most part). Need more info - does this happen cold or hot? What engine and carb?
Old May 9, 2007 | 10:46 PM
crazyman112222
its a 351 m in it the carb is a dubble barrel motorcraft
Old May 9, 2007 | 10:50 PM
crazyman112222
this happens both ways
Old May 9, 2007 | 11:27 PM
fmc400's Avatar
fmc400
MSEE
I would try two things: first make sure the accelerator pump on the front of the carb is functioning correctly. With the truck all shut down you can take a look down the throat of the carb and open the throttle. You should see two nice streams of gas squirt at the venturis. Secondly I would check your timing with a light.
If neither of those nail the problem I would check for vacuum leaks and run a compression check.
Old May 9, 2007 | 11:29 PM
crazyman112222
ok ill try that thank you
