Won't shift
Old May 9, 2007 | 05:20 PM
99350psd's Avatar
99350psd
Won't shift
99 F350 7.3 Overdrive button is blenkind and the tranny won't change smoothly. Big jerk between 1 and 2 then hard shift the rest of the way. Need help!
Old May 9, 2007 | 05:31 PM
mongo75's Avatar
mongo75
Brother, sounds like you got big problems. I had the same issues sorta when my tranny pooped the bed. I would check your battery terminals and make sure you have good contact- reason being is that right around the time mine died, it kept throwing a KAM code (keep alive memory) and I don't know if or what problems that may have contributed to my tranny failure, but it kept "resetting" my ECU or something like that. I HOPE it's not serious, but it sure sounds that way.....
