Cam a 300 or swap in a 351?
Old May 9, 2007 | 04:16 PM
bchunter's Avatar
bchunter
What would you guys do if you are looking for some more power? Put a cam in the 300 that is already in the truck (Crane cam 503901, a mild grind) or swap in a 351? The cost for me will be about $700 cdn more for the engine swap, that is complete with the wiring harnesses from the donor truck and includes the trade in of my engine.
Here is how I use the truck. I have a 4000 lb boat and a 6000 lb travel trailer that I pull with it. I use it as a daily driver never going over 100 km/h (65 mph). I don't wheel it hard but use it to crawl through the bush during hunting season and pull out trees for firewood. I take it on the odd trip over 2000+ kms.
It is a 96 F150 4x4. It has the stock D44 TTB and stock 8.8. It has 4.56 gears with open carriers front and rear, the M5OD tranny, and 35's. I am also wondering if the drivetrain can handle the 351. From some guys I have talked to they say that it can.
I need some more gusto when pulling and general highway driving and am wondering if the cam will do this for me, as I am sure that the 351 will.
Thanks for all the help.
Old May 26, 2007 | 06:56 PM
Mtthwvn73's Avatar
Mtthwvn73
The M5OD couldn't handle the 351...way too much torque. If I were you, I'd just cam the 300 and do a little more performance stuff to it. Since it's a 96, it can handle alot more mods. A cam and a good exhaust would really help it, I'd say.
You'd still get *deacent* gas mileage (especially better than the 351). You won't have as much power with the 300, but it will be alot less work....that is, unless you carb the 351.
I have an 88 bronco, and when I rebuild it I plan on putting a carb on it, not just for the cost, but alot less headache since I plan on doing some headwork and adding a good cam to it.
Old May 27, 2007 | 02:57 PM
pud's Avatar
pud
too late matt, the biotchsky is in there and runnin good. The 5 speed will be fine, its not going to go boom at least, it just might wear out a little sooner.
Old May 28, 2007 | 02:52 PM
Mtthwvn73's Avatar
Mtthwvn73
Lol, just a little too late.
I've always heard, though, that the M5OD is only rated for 300 Lb.ft of torque, and a stock 351 is putting out 317 (at least my 88 bronco does). So I don't know how well it will hold up. Make sure to let us know how it's going!
Matt
Old Jun 3, 2007 | 11:08 PM
jolly774's Avatar
jolly774
Matt
Thunderbird SC's had M5R2s (basically the same except synchros) and they can handle 400+ ft.lbs.
Old Jun 4, 2007 | 12:05 AM
Mtthwvn73's Avatar
Mtthwvn73
You sure we're talking about the same tranny???
Didn't the SC only have a 2.3L's? if so, it was only an M5OD R1 (the same thing they put in the rangers), it's a smaller verson that isn't as strong as the R2, which is in the fullsize trucks and bronco's. Never heard of them holding that much torque.
They aren't a heavy duty tranny...The ZF5's are only rated at 420-470 pound feet of torque, and the M5OD was never put behind a 351 from the factory, which has only 317 pound feet of torque.
