428 Police interceptor engine
The engine is loose and the guy told a friend of mine that he took it out of an old cop car. We will be looking at it in about a week. Even if its not an interceptor, the price is fair and I will probably pick it up anyways.
Morris, Rob did some internet digging and got me a whack of block, head, and intake casting numbers. Once i get it I might get your books and who knows, with some persuasion, might get your expertise out to the farm to look her over.
We did quite a bit of homework. It sounds like that thing made some good power - Ford rated hp @ 345-360 and torque around 460. Some articles said hp closer to 400. They rated the CJ and SCJ at 335 hp and 440 ft lbs.
One interesting tidbit - the aluminum intake shaves 55 pounds off the engine vs the cast one and is identical to the CJ as far as flow is concerned.
Received 1,372 Likes
on
on
on
From mid 1968 thru 1970+ the 428 CJ Mustangs owed most drag strip records in it`s classes.
We were lucky enough to have a 428 67 Fairlane racing at SIR thouygh I had to work Sundays and never got to see it. One day it rolled while out on the track and was gone forever....
a way to get a rough ideo is to take a spark plug out and stick a dowl inside and get a rough idea of the stroke. not perfect, but fairly accurate, as some block numbers on FE's were repeated i believe. if it is an aluminum intake, and it looks like an original intake, that points to it being diffrent than a regular FE.
428PI were used in 68 Shelby's
