1978 - 1996 Big Bronco
Speedometer
Old May 9, 2007 | 10:00 AM
95bronc5spd's Avatar
95bronc5spd
Speedometer
What is up with everone. well i got a problem i was offroading and got it stuck for to 2 1/2 days thats another story. well turns out that after i got pulled out my speedometer does work anymore and does anyone now were the timing marks or on a 95 bronc. thanxs
Old May 9, 2007 | 10:20 AM
muckypaws's Avatar
muckypaws
check the sensor on the rear axle - there is a hall-effect device back on the top of the axle that control the speedo, ABS etc. They suffer from water ingress which screws them up. Give the connector a good clean. They can be tested but I can't remember the parameters off the top of my head.
A new sensor doesn't cost much (unless you are in the UK, LOL!)
