Bronco II Ford Bronco II
fan direction
Old May 9, 2007 | 07:44 AM
milesad's Avatar
milesad
Thumbs down fan direction
i put a new water pump on. i forgot which way the fan wnt back on? should it blow into the radiater or the engine( drawing air through the radiator)?
Old May 9, 2007 | 08:06 AM
kernel-panic's Avatar
kernel-panic
Should draw air through the radiator... uhm, did you separate the plastic fan from the clutch? Shouldn't have had to, that I'm aware of....
Old May 9, 2007 | 12:58 PM
milesad's Avatar
milesad
well then its on right. and yes I did seperate it from the super clutch, actually put a new one on. because I busted the old one with a hammer.
BigBlueCat
May 25, 2014 02:16 PM
ZOOT
Jul 21, 2013 06:38 PM
1fast4.6
6.4L Power Stroke Diesel
Jan 22, 2013 08:52 AM
ocalhoun
Aug 18, 2011 12:12 PM
mhilow
1983 - 2012 Ranger & B-Series
Dec 20, 2006 08:35 AM
