duraspark
Old May 8, 2007 | 11:35 PM
rbcyouthdude's Avatar
rbcyouthdude
duraspark
I have a 1966 f-100 with a 1982 400M block engine. It has a point distributor. After looking at the duraspark systems online my distributor looks just like a duraspark. Could it have been converted to points? If so should I go back to duraspark or to pertronix?
thanks
Michael
Old May 8, 2007 | 11:54 PM
ihateminimumwage's Avatar
ihateminimumwage
Two piece dizzy or the Duraspark II with the wider points and the three piece dizzy?
If you're running an 82 motor, I'm guessing DS II. Keep it, it was updated for a good reason (so I've been told, although I had less headache from my '70)
I'm not much help I guess...
Old May 9, 2007 | 12:11 AM
Torque1st's Avatar
Torque1st
Posting Legend
Convert it back to the DS-II blue grommet system. There are thousands of wiring harnesses and parts available on truck and cars in the salvage yards. Pick up a couple of Motorcraft DS-II modules and have them tested at the parts store. Mount the module on 1/4" spacers for cooling.
User BB's Duraspark diagrams:
https://www.ford-trucks.com/forums/member.php?u=1811
Old May 9, 2007 | 06:58 AM
rbcyouthdude
Ok, I can just put the duraspark stuff back on without taking out the dizzy right? How can I know if it is a duraspar distributor, it sure looks like one.
Michael
Old May 9, 2007 | 08:42 AM
rbcyouthdude
Ok, after checking it is not a duraspark dist, it is an autolite 12127. So to upgrade without pulling the distributor it's pertronix I guess.
Michael
Old May 9, 2007 | 10:05 PM
Torque1st's Avatar
Torque1st
Posting Legend
I have no idea what that number means. Pulling a dizzy is not difficult unless it has corroded and sticks. That will be a problem no matter what you do when you need to set the timing. Putting in a distributor is not hard either. I have done it enuf times I can do it in my sleep now.
Old May 16, 2007 | 11:53 PM
lucky no. 7's Avatar
lucky no. 7
dont be skeered of it now ya hear, lol
