Cooling system question?
Old May 8, 2007 | 12:48 AM
Mr. Bob's Avatar
Mr. Bob
Hey Guys...
Being new to the PSD I had a question about antifreeze... I come from the IDI world where running the right antifreeze in VERY important....
I was looking at my antifreeze, and it looks to be original ( 2002 ) and the frod extended life antifreeze. When I flush it can I go with regular green antifreeze? or is it important to run the gold coloured stuff???
Secondly, just as with the IDI is it important to run a ford or IH thermostat??? not an aftermarket??
Thanks for the help!!!
Bob
Old May 8, 2007 | 03:50 AM
ron's power stroke's Avatar
ron's power stroke
yes you can swap to green just make sure you get all the gold out of the system..the 2 blending is not a good thing...you need to use a ford thermostat..IH is different..you can use a 203 stat from http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=186 id also get this too http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=188
the factory one is junk once you remove it.
Old May 8, 2007 | 07:54 AM
NS F250's Avatar
NS F250
Why would you want to switch to the green stuff? I thought the gold stuff was the ticket because you don't have to mess with additives and test strips. Is there something wrong with using the gold stuff I'm not aware of? Not trying to knock you, just wondering because I have two trucks in need of a coolant change pretty soon.
Nick
Old May 15, 2007 | 07:26 PM
Mr. Bob's Avatar
Mr. Bob
hmmm.... any more input????? I have one yes and one no.... Doesn't ford run the gold antifreeze in both gas and diesels???
if switching to green its still smart to run the antifreeze additive like in the IDIs??
Old May 15, 2007 | 07:31 PM
Uzumati's Avatar
Uzumati
If you run green you HAVE to do the test and keep additives at proper levels. If you want trouble free look into the RED HD ELC's (not the normal orange ELC's) ie, Shell Rotella HD ELC, Final Charge HD ELC that meet CAT EC-1 specs. http://www.finalcharge.com/finalcharge5050.html
Old May 15, 2007 | 08:18 PM
aklim's Avatar
aklim
Some more reading for you
http://www.internationaldelivers.com...pdf/dyk299.pdf...
Old May 15, 2007 | 09:35 PM
clux's Avatar
clux
There's red ELC in my block. Long life, best protection, and its purty, too.
Old May 15, 2007 | 10:05 PM
Mr. Bob's Avatar
Mr. Bob
http://www.texaco.com/yourcar/havolinecoolants/findRightCoolant.asp
So the first one??? the one that also meets gm Dexcool standards?? This is the orange stuff, but is the only ELC I see on the texaco website... is this what IH uses to factory fill???
Old May 15, 2007 | 10:10 PM
Uzumati's Avatar
Uzumati
That is an ELC not an HD ELC
Old May 15, 2007 | 10:24 PM
Mr. Bob's Avatar
Mr. Bob
That is exactly what I suspected....
Is this not the product ( TELC ) that is mentioned in the link provided by aklim???
Old May 15, 2007 | 10:37 PM
Uzumati's Avatar
Uzumati
The TELC in aklim's link is described as rasberry red, that is HD ELC
The dexcool (orange) is what you dont want
I have never seen a 300,000/600,000 mile red coolant from texaco in the stores only the Rotella and Final Charge
