Weeeeird noise.
Old May 8, 2007 | 12:02 AM
Slow96's Avatar
Slow96
Weeeeird noise.
So a while ago, after washing my truck I started to notice a very strange noise coming from around the glove box area...It sounds like trickling water or clicking..Very odd. A friend thought maybe the rad had air in it, so we popped the cap off and ran the truck for a bit..No luck. I have since changed the rad fluid(once drained it all..then had to do rad work...) and still...Same problem. If it IS the rad, am I trying to get the air out the wrong way? Anyone know what else it could be? Doesn't seem to effect performance, just makes a weird, annoying noise.
Also, sometimes when I let the clutch out, the truck seems to bog or feels like the clutch is slipping..then grabs hard and is fine. I am pretty sure it is not the clutch because I can't smell it burning, and it doesn't slip other than that.
Old May 8, 2007 | 07:00 AM
Tikka Dude's Avatar
Tikka Dude
The sound behind your dash is most likely your heater core. Nothing to worry about until if/when it goes out...
Old May 8, 2007 | 09:39 AM
NeXtras's Avatar
NeXtras
i get the same sound, i've been told its normal for that generation of ford trucks.. i hope ne ways... i hear that sopund a lot
Old May 8, 2007 | 03:27 PM
t4kne's Avatar
t4kne
If it sounds more like clicking, and is random, it could be the wiper control unit.
Old May 8, 2007 | 04:02 PM
Skandocious's Avatar
Skandocious
I think I have the same noise that your talking about Slow96. After the truck has been shut-off it will make noise for around 20-30 seconds, sounds like a vacuum leak or something... I hope not!! There was a thread about this a few months back and I think there were 10+ guys that all said their truck did it after shutting off. I don't think it's much to worry about.
-Chris
Old May 8, 2007 | 05:35 PM
mhg's Avatar
mhg
when you shut your truck down with the a/c on
you will get a hiss while the freon equalizes
from the low to high side at the orifice
Old May 9, 2007 | 06:04 AM
NeXtras's Avatar
NeXtras
my noise is prticulry afte you strt the truck nd drive for few minutes, if u hit the gas a little u'll hear a trickiling water sound... i'll try to record it some time
Old May 9, 2007 | 09:30 AM
Slow96's Avatar
Slow96
There is no noise when the truck is shut off. It seems to do it most when the truck is cold and I hit the gas. It will also do it when the truck is warm though too.
Old May 9, 2007 | 09:31 AM
Slow96's Avatar
Slow96
That's exactly what mine is...And no one knows what it is or how to stop it?
Old May 9, 2007 | 04:15 PM
tjc transport's Avatar
tjc transport
i ain't rite
i bet someone changed the heater core, and put the coolant lines on backwards. so now, instead of the coolant going into the bottom of the core and filling it up, then flowing out the top, the coolant goes into the top of the core and pours down and out the bottom. this will cause a water rushing or gurgling sound.
Old May 9, 2007 | 05:09 PM
ACarbone624's Avatar
ACarbone624
my truck makes that flowing water sound...I thought it was air trapped in the heater core...i only notice it when its cold though... I only notice it if the radio is off.
Old May 11, 2007 | 09:34 PM
NeXtras's Avatar
NeXtras
hmmm that sounds interesting... is it easy to cross those hoses?
Old May 11, 2007 | 10:32 PM
Georgia F150's Avatar
Georgia F150
I'm lookin at mine in the morning...My HC makes the same sound...
Old May 12, 2007 | 04:56 AM
tjc transport
i ain't rite
very easy to swap the hoses. since the core is higher than the radiator, you don't even have to drain any coolant.
it is best though to find a service manual, and look for the proper hose routing diagram to make sure you have them on properly though. my newest book is for the 91, so i can't look up the line placement for you..
Old May 12, 2007 | 04:40 PM
NeXtras's Avatar
NeXtras
but the heater core is horizontal so i dont think it would really matter... i have a pic from the service manual cd i have
does it still make much of a difference?
