C.C. Help needed.
Old May 7, 2007 | 11:55 PM
jefxxo's Avatar
jefxxo
C.C. Help needed.
Recently when I put on cruise control say at 70, it will give gas then abruptly stop and then go again. After a few times It will jump up to about 80-85 then shut down till I hit just below 70. It will keep going from 70-85-70 a few times then just shut off completly and I will have to turn C.C. back on. Any ideas what is going out or needs to be looked at? Thanks Jeff
Old May 8, 2007 | 08:21 AM
quicklook2's Avatar
quicklook2
what year?
Old May 8, 2007 | 08:30 AM
jefxxo's Avatar
jefxxo
Its a 95 I-6
Old May 8, 2007 | 09:30 AM
quicklook2's Avatar
quicklook2
dirty sensor in rear end, dirty ring gear, vacuum leak, loose wire.
does horn work normally?
Old May 8, 2007 | 11:48 PM
jefxxo's Avatar
jefxxo
The spedo has been jumping around above 70 for about 3 years. But never had a problem with the C.C. The rear is new and I know is clean. But it has been getting louder over the past year or so. And I think will go out again before long. Where are there vaccume lines for the CC.
Old May 9, 2007 | 08:14 AM
quicklook2's Avatar
quicklook2
the sensor in your rear end needs to be replaced or cleaned.
the rear end in your truck.
Old May 9, 2007 | 08:49 AM
S_Bruce's Avatar
S_Bruce
Isn't there a recall on the cruise control units for that year? I have a '95 and thought I remember getting a recall notice in the mail. If so, have the dealership fix it for free.
Old May 9, 2007 | 08:56 AM
quicklook2's Avatar
quicklook2
true, but that is probably not why it is not working.
call your dealer with vin to see if recall fix has been done.
Old May 9, 2007 | 09:23 AM
subford's Avatar
subford
If you find out how to fix this one let me know as I have a 1995 302 doing the same thing.
I have gone though the rear on this truck so I know it is not that and there is no vacuum connection to the CC on a 1995.
The speedometer does not jump at any speed so I do not think it is the PSOM module.
