Sponsored by: Real Truck
Good Source for U-Joints?
Old May 7, 2007 | 12:34 PM
ottr1967's Avatar
ottr1967
If anybody has any recommendations for good quality u-joints for the rear drive-shaft on my F250 please let me know.
THANKS
Old May 7, 2007 | 01:02 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
For stock strength, just make sure the u-joint says "spicer" on the end-caps
The only difference is they actually come with grease fittings
A local truck parts place (mostly heavy-duty stuff) had my u-joints in stock, for something like $16. True spicer, in a spicer box.
Even Napa might supply spicer, just open the box and look at the end-caps.
If you're into something more heavy-duty than stock (although it could be argued that spicer joints ARE an upgrade from the stock Ford spicer-supplied non-grease-fitting joint)... someone else will comment on this soon, I'm sure.
Old May 7, 2007 | 04:59 PM
ReAX's Avatar
ReAX
I use precision, I just am sure to order the ones with out grease fittings. Precision say's non-greasable joints are 40% stronger than grease joints. I can see it, if you consider they have to drill channels into each lobe.
Spicers are good, probably better than precision, but precision has done me well.
Old May 7, 2007 | 05:38 PM
krewat's Avatar
krewat
Good point, ReAX, about strength...
Old May 7, 2007 | 09:01 PM
high ho silver's Avatar
high ho silver
Brute Force (non-greasable) have had no problems
