Help me build it.
Old May 7, 2007 | 12:19 PM
skawez's Avatar
skawez
Smile Help me build it.
I have a 1984 f-150 351 WINDSOR HO 2WD.
I am pulling the motor out to reuild it. it is my first complete rebuild.
I want to have some power say... 400-425HP with ample torque.
i have a 650 edlebrock 4bbl that is on the truck now.. with the cash planned to go into this i will upgrade it but would be ok with it as is.. i plan to have headers 3" dual exhaust ... what i would like to know is everything else cam, pistons, rockers, intake, ignition, bore.. so you know what i want to use it for.. hunting camping towing ... oh and i got to beable to put my foot in it and leave the other guys in the smoke ... yes with a boat hooked on. cash wise.. say 300 a week for 6 months so around the 7000 mark but would like to keep it around 3-5000. it is an automatic and would like to keep it that way. thank you for your help.
Old May 7, 2007 | 06:04 PM
Franklin2's Avatar
Franklin2
The only way I see you are going to get near that horsepower, and be able to still tow with it, is to put a supercharger system on it.
You don't get that kind of horsepower, without moving the redline way up. This means revving the motor to get power. So that means a stall convertor for the tranny and something like 4.11 gears for the rearend. Not much fun to drive something like that.
Old May 7, 2007 | 08:39 PM
skawez's Avatar
skawez
ok then....
ok then.... well how about some wehre in the range of 350385. stock tranny & rear end? deep dish pistons. a 750 cfm carb and a .512 .520 cam?
Old May 7, 2007 | 08:56 PM
Franklin2's Avatar
Franklin2
I would look at one of these kits. No guess work. Already dyno proven with the graphs and a complete list of parts to do it.
http://www.edelbrock.com/automotive_...nd_kits2.shtml
But I am warning you. Look at the graph. Even though they claim the powerband starts at 1500rpm, the graph doesn't start till 2500 rpm.
Old May 7, 2007 | 09:04 PM
Franklin2's Avatar
Franklin2
I went to www.jegs.com. and that 400hp package is about $1734.00.
http://www.jegs.com/webapp/wcs/store...0002_595675_-1
Old May 7, 2007 | 09:17 PM
dmanlyr's Avatar
dmanlyr
I agree 110%. SUPERCHARGER is the ONLY way that you will accomplish what you want to do. I have NEVER been shown a dyno chart of a true 400+ hp 351w (stock 2v heads) in street trim (air cleaner , exhaust, mufflers) and with a max of 5000 rpm (heavy truck - hard to tow with a peaky 6000+ engine)
And yes, I have asked repeatedly for dyno charts, of which I have been informed there are "thousands" out there. Looking at the dyno chart, I see a max of 6500 rpm shown on the 367hp engine. Now that is not a usable street rpm range for most of us, on a daily driver, to say the least in a heavy truck, and what about below 2500 rpm? Seems more than hokey to me. it would however, be fun in a light Mustang
Yes, you can get 4000+ hp out of a 426 based Hemi also - but look at the short life and the totally unusable (for the street) rpm range. (when was the last time you saw a top fuel dragster on the freeway towing a boat? But it has 4000+ hp .......
More reasonable is the 335 - 355 range as you have figured out. A good single four barrel 600 to 700 cfm, head work/clean up, reasonable compression of say 9.5 to 1 and medium duration, high lift cam, premium fuel required, a low restriction air cleaner w/cold air induction for the summer, switchable for hot air in the winter (unless you live down south) and headers with a balance tube should give you about All that you are going to get. A rear end ratio of about 3.55 with the AOD will maximize fuel economy, plus give you the ability to tow in direct. Unless of course you have large tires.
I see that you have a automatic - it will need to be reprogramed / mechanicaly modified if you want the up the operating range to 6000+ rpm, unless you manually hold it in the lower gears.
David
Old May 7, 2007 | 11:38 PM
86bigred's Avatar
86bigred
why not go to big block,my 460 has gobs of bottom end.can't beat cubic inches.
Old May 9, 2007 | 07:33 PM
skawez's Avatar
skawez
well
i think ill go with a comp cam .272...... that wasy ill have all around pwer and yet still have some gas left sound good?
Old May 9, 2007 | 07:45 PM
Dustin1690's Avatar
Dustin1690
Sure does as long as your happy with it!!..
Old May 9, 2007 | 11:27 PM
art015's Avatar
art015
Go with a 408-417 stroker kit and a modern hydraulic roller cam. Or do what I did, 460!
Old May 10, 2007 | 12:55 AM
hoxiii's Avatar
hoxiii
Bang for your buck a 393 stroker is the way to go to get big torque and HP numbers at a reasonable RPM range. There's no reason a 393 couldn't make 390hp and 430 ft*lbs (with aftermarket heads) and not be 100% streetable and towable.
Heck, 300hp and 400ft*lbs will do ALOT more than you'd ever expect and that's a pretty mild build on a 393. Plus it'll be all in by about 45-4800 RPM for hp and 25-2800 for tq.
Justin
Old May 10, 2007 | 05:44 PM
Franklin2's Avatar
Franklin2
Yea, but 300hp doesn't hold much weight during bench racing.
lbumpers
All Things Towing
Jan 19, 2014 09:43 AM
preppypyro
80
Jan 3, 2008 12:47 AM
