Sponsored by: Real Truck
Auto-trans Questions!!
Old May 7, 2007 | 11:13 AM
RAM7880's Avatar
RAM7880
Question Auto-trans Questions!!
anybody know if there is any difference between the 250 and 350 transmisions (1999-2002) and what there life expactancy is?
Old May 7, 2007 | 11:24 AM
DonJames's Avatar
DonJames
Same 4-speed autos. Model 4R100. Problems with very limited ATF (automatic transmission fluid) flow when towing and stomping on gas, full throttle and slow acceleration (mean a heavy load). Problems with transmission burning up and slipping. Expect long life if not towing with it.
Install Banks TransCommand before any slippage occurs:
http://www.bankspower.com/tech_whyaddatranscommand.cfm
Old May 7, 2007 | 05:05 PM
ReAX's Avatar
ReAX
I don't like the electronic line pressure units. Invest in an accumulator/valve body/shift kit. You need more volume as well as pressure to keep the trans cool. I am very happy with my factory tech valve body, simple install and I can chirp second with a n/a 5.4L.
Diesel/lightening transmissions were beefed up more than the 5.4/6.0. Other than that, they should be interchangable.
Old May 7, 2007 | 05:55 PM
fordv10's Avatar
fordv10
I second the factory tech valve body.I have an 02 Dually 4x4 with the 4.30s and I can also chirp the 4 rear tires at full throttle first to second gear shifts. On my old 99 it had the Banks Transcommand on it and it never shifted this hard.
