Cab change question.....
Old May 7, 2007 | 11:04 AM
ace5107's Avatar
ace5107
Hi guys. I have a 92 4x4, 302 auto and I am going to change cabs with a 92 302 auto 2wd...... do I need to switch wiring harness from my cab to the donor, or will my electronic shift wires plug into the other harness? Thanks. Gene
Old May 7, 2007 | 12:14 PM
95Ford4x4's Avatar
95Ford4x4
my 95 2wd had the harness to plug into the 4wd indicator switch. not sure about the push button 4wd stuff though. you should be able to do a close inspection and figure out what you may or may not have to swap out. i'd pull the instrument cluster on both trucks and see what kind of wiring setup they have.
