couple questions
Old May 6, 2007 | 11:27 PM
muddingmcdude's Avatar
muddingmcdude
couple questions
well soo i finally got my boat back and i towed it with my new motor... still seems doggie i dont know what im suppose to expect but i was kinda annoyed that i had to keep it floored to keep speed up some hills (88 23 ft fourwinns) how much differnce would there be if i spent teh money on gauges and turn up the fuel and boost? cuz there has to be more power outta that motor it only has 10,000 miles on it ooo and is there ne thing to do to fix my speedo its like i gota go liek 65 to do around 60 and it bounces once over 70 and my cruise bounces thru all the speeds??
Old May 7, 2007 | 09:50 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The 94 used a sensor mounted in the rear differential to drive the speedo.
Be careful, usually when the speedo goes flakey, the tranny goes into limp mode and should not be driven.
Old May 7, 2007 | 09:53 PM
muddingmcdude
well the tranny seems to shift fine little soft acutally but like i said b4 its on its way out it shutters thru first gear speedo does fine till after like 70
