cam problems 2
Old May 6, 2007 | 01:19 PM
Ford420CI's Avatar
Ford420CI
Angry cam problems 2
hey guys I am still having a problem getting my motor to turn over. I took the starter out and it turned 3/4 turn then it stopped. Now it almost feels like i am pushing against a spring. Is it possible the the motor is 180 degrees out of time even though the timing marks line up?
Old May 6, 2007 | 02:33 PM
Conanski's Avatar
Conanski
You are probably going to have to pull the valve covers off and inspect everything for a stuck valve or broken/jambed pushrod. Maybe try unbolting the rockers to see if that helps. If it does them maybe you have the wrong pushrods in the motor or something else isn't right.
