ball-joints
Old May 6, 2007 | 01:10 PM
bbenard2's Avatar
bbenard2
ball-joints
I have a 1990 f150 2wd, Is it possible to do the upper and lower ball-joints in my driveway?
Old May 6, 2007 | 01:21 PM
lostin90s's Avatar
lostin90s
Yes you can rent /borrow the press (looks like a big c-clamp) or take and have pressed in at a garage. ,tie rod fork (for tie rod and to drive in around old balljiont to help separate everything(May need big hammer) . Get a good manual and allow a weekend per side. (just in case) The fist one will take all day and second 45 minute least it works that way for me. Good luck Keep us posted . Look at some post over last week this has came up sevseral times some good info .
Old May 6, 2007 | 01:32 PM
bbenard2's Avatar
bbenard2
Is that a general guideline, or is that specific to this truck? I'm not sure what configuration it has.
Old May 6, 2007 | 02:01 PM
giuntoc's Avatar
giuntoc
It should just be a general guideline. I did them on my 95 4x4 and it went like that for me too. Check your tie rod ends while you are doing the ball joints. You should get a tire alignment afterwards and if your tie rod ends are bad you can save yourself from getting two alignments down the road.
Lazy K's Avatar
Lazy K
What lostin90s says is general guide and will work for your truck. As he advises get a manual as there are other things you will have to do. Not a major job but can be time consuming if you have not done it before.
Old May 6, 2007 | 04:51 PM
bbenard2's Avatar
bbenard2
Thanks gentlemen.
