intake problem
Old May 6, 2007 | 12:36 PM
66f100352's Avatar
66f100352
intake problem
ok so I have this nice S code intake and last night I went to go clean it and noticed that my water by pass is serverly rusted and rotted to the point of being non useable..can I replace this pieace and if so how?? Can I pull one off another intake and tap it into mine? Or is it intake shopping time again Thanks
Mark
Old May 6, 2007 | 01:18 PM
73F100*8Mile's Avatar
73F100*8Mile
No worries, I drilled mine out very carefully, pipe threaded and installed a brass nipple w/ no prob's yet. You can also take it to your local machinist and have him do it reasonably priced if you're not able to.
Old May 6, 2007 | 01:21 PM
66f100352's Avatar
66f100352
Yeah this one is so bad I won't be needing to do any drilling lol...when you say pipe threaded did you need to tap it or anything or is it kinda a self tapping thing?
Old May 6, 2007 | 01:26 PM
73F100*8Mile
Ya I work in a shop so I had all the tools at my fingers. I used a brass pipe that pops gave me that was already threaded on one end so I just found the matching tap and tapped out the manifold. You've gotta be dead on center though b/c you're tapping cast iron and it is very brittle. It will either tap or just tear chunks of iron out and then you're up the creek. Get a price from your local machinist. Couldn't imagine it being more than 40-50 bucks.
Old May 6, 2007 | 01:33 PM
66f100352's Avatar
66f100352
yeah I think I'll go that route...hopefully the rest of it will clean up just fine
Old May 6, 2007 | 01:40 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
If the hole is the intake is not badly rotted/pitted you can install a stock size tube. Tap it in with some locktight/sealer etc...on it and go. DSC has them for $2 or NAPA I'd imagine would have them. Local plumbing house/HD might have something the same size. Pretty easy fix.
G.
Old May 6, 2007 | 01:45 PM
66f100352's Avatar
66f100352
Hmmm well do you think I can pull out my old one from my 2 barral intake?
Old May 6, 2007 | 01:56 PM
arctic y block's Avatar
arctic y block
No. I believe ya would destroy a used one trying to get it out. Clean it all up and make sure ya have no other problems than take it to a shop and have a pipe nipple put in.
Old May 7, 2007 | 10:03 AM
ranch67's Avatar
ranch67
make sure your replacement elbow has tube below the threaded part.
(extends into the manifold) you dont want air to get sucked into your heater lines. if you hook up your heater?
Old May 7, 2007 | 10:09 AM
Redmanbob's Avatar
Redmanbob
yep used plain old copper/brass? pipe from the plumbing section on mine. The mallot made a nice nipple end once it seated up. Works great.
mikey1968
Jun 28, 2016 02:14 PM
Nseal1996
Aug 2, 2014 08:33 PM
Damifiknow
May 1, 2014 04:16 PM
maverick600
19
Feb 7, 2013 11:38 AM
