AOD trans interchange..
Old May 6, 2007 | 09:53 AM
neon4x's Avatar
neon4x
Could anyone tell me if the linkage on an AOD trans from a 90 thru 93 van is the same as the F150. Salvage yard dude told me they were fully interchangable without having to change the linkage but only 90 thru 93. My door tag shows trans type as "T"
1990 F150 XLT Lariat 5.0L AOD trans 2wd
Old May 6, 2007 | 07:48 PM
ReAX's Avatar
ReAX
Sounds good to me, I would only expect the cables to be longer on the p/u. The brackets should be slightly different, but not enough to cause issues.
