rear diff issues
Old May 5, 2007 | 09:01 PM
boss429_1969's Avatar
boss429_1969
Question rear diff issues
I have a 1996 F250 which i purchased recently. I noticed that the rear differential looked like it had been leaking lube. I changed out the lube and put in Mobil LS 75w-90. This lube is supposedly compatible with limited slip rears, but after putting about 20 miles on the lube change, i noticed that the rear was vibrating when i made turns (enough to make the rear work). I just want to know what i can do to fix this short of changing it again, like is there an additive i can put in. If i do have to change it again what would be the best stuff to buy. Any help is much appreciated. Thanks.
Old May 5, 2007 | 09:26 PM
75F350's Avatar
75F350
Friction modifier from your local Ford dealer.
Cheap enough, and better than most of the aftermarket additives.
