put the first 200 miles
Old May 5, 2007 | 08:00 PM
tomoto's Avatar
tomoto
1 front caliper froze up ,the rim was so hot,the tran goes by 3 the overdrive, needs a new oil pan, but it drives like a new truck .its made for the high way. it sit to low ,I'm going to put in new front spings
Old May 5, 2007 | 08:05 PM
53fatfndr's Avatar
53fatfndr
Glad to hear you got it on the road. It's time to start breaking it in and adjusting things.
Old May 5, 2007 | 08:17 PM
doug51f1's Avatar
doug51f1
WooooHoooo!
Glad you didn't give up on it! See how much more fun it is when you can drive it?
Congrats on getting it on the road!
Old May 5, 2007 | 08:23 PM
jimhackney's Avatar
jimhackney
Congrats on getting on the road. Makes all the hard work worthwhile. Now for the tuning phase. It'll get better the more miles you put on it.
Old May 5, 2007 | 08:34 PM
raerjim's Avatar
raerjim
More pictures please!
Old May 5, 2007 | 08:37 PM
WALFORD'S 56's Avatar
WALFORD'S 56
Sounds awesome!!!You definately are a true craftsman and post more pics,please
Old May 5, 2007 | 09:03 PM
tomoto's Avatar
tomoto
bad news my oil pressure is off, before the oil was up to about 70, now its below 20 pounds driving and about 1 at the stop light. I just read at HAMS that I use the wrong oil to brake in the motor . it would had ben nice if the engine builder had told me to use a right oil ....all that money is trash so is this truck
Old May 5, 2007 | 09:27 PM
49fordpickumup's Avatar
49fordpickumup
Trucks
I don't see all the details confirming a trashed engine. Bad oil guage, oil transmitter., oil pump, what indications. I've seen guys use regular oil after overhaul, not brake in oil. They never had a problem. Brake in oil is best. Maybe later engines require brake in oil. Give more information. Frosty and think time,Chuck.
Old May 7, 2007 | 08:52 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Glad you got it running! Don't worry somuch its probably all fine. As Chuck mentioned, sip a frosty (or two) and start debugging it one step at a time
Good luck
Bobby
Old May 7, 2007 | 02:54 PM
1Digger's Avatar
1Digger
What are you calling "break in" oil. I always thought you should use SAE 30 for break in and change it after that. Right-Wrong?
Old May 7, 2007 | 02:59 PM
jimhackney's Avatar
jimhackney
Engine
Was your engine overheated when you noticed the oil pressure at 0. I noticed mine was at 0 back when I had the overheating problem if it got too hot.
Old May 7, 2007 | 03:33 PM
53fatfndr's Avatar
53fatfndr
If you run a flat tappet cam, you should use a diesel grade oil such as Chevron Delo 400, or Shell Rotella-T. The newer gas engine oils do not have the added protection for older engines. As a result, newer engines that are broken in with the newer SM?? rated oils are finding out that they are wiping their cam lobes. The newer oils have a lower zinc content do to emissions, and the fact that most newer engines run roller cams. There are plenty of discussions on this topic in the oil forum. Do a search in that forum on "Rotella" or "flat tappet", lots of topics there.
And, just for the record, I am in no way implying this is Tomoto's problem, I am just replying to 1Digger's question. As to Tomoto's problems, I'm with Chuck and BobbyT on this. Check things out before you assume the worst.
Old May 7, 2007 | 03:57 PM
tomoto's Avatar
tomoto
the zinc has been remove from Rottello , no it never got hot ,200 then the fan can on it drop 180. I did not push it ,My trans is bad to and it was rebuild by a tran shop, goes right by 3 to 4. But the frame and truck drove like a new truck ,and the looks I got would have kill ..I'm pulling the motor today,I had the pan off last night....I'm told not to put a high volume oil pump,with the stock pan. so i guess to truck is done and going to be park ..
Old May 7, 2007 | 08:04 PM
Dustin1690's Avatar
Dustin1690
Well good to hear you stuck to it and got through with it and now its on the road.. grats
fire240
2009 - 2014 F150
86
Oct 5, 2016 06:28 PM
2011SD
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
17
Apr 14, 2015 08:33 AM
therigwelder
1997 - 2003 F150
Oct 7, 2013 09:32 PM
Denola
Feb 3, 2013 07:20 PM
fordomatic
Oct 12, 2003 06:07 PM
