Distributor problems with enging swap
Old May 5, 2007 | 07:45 PM
frty7ford's Avatar
frty7ford
I am working on an engine swap for my daughters 65. I pulled the 352 and had a friend give me a 390 to put in it. The 390 had an electronic dist and has a smaller distributor shaft. I am looking for info for a point type.
Old May 5, 2007 | 08:38 PM
Freightrain's Avatar
Freightrain
? Smaller shaft?? Something is not right. Are you wanting to put your 352 distributor in? Should drop right in.
Old May 5, 2007 | 11:17 PM
frty7ford's Avatar
frty7ford
I thought it would too. the dist housing are the same the the center rods are different.
Old May 5, 2007 | 11:20 PM
Scouder's Avatar
Scouder
This is a new one for me. The 352 dizzy should bolt right in. How is the center shaft causing a problem? Besides, how small can it be? I has to drive the same size oil pump shaft as the other one.
-Scouder
Old May 6, 2007 | 08:11 AM
HOTWRENCH's Avatar
HOTWRENCH
Talking
It sounds like the 352 was built from a FT block that would explain the
larger oil pump drive. Hotwrench
Old May 6, 2007 | 08:24 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Bingo. That might be it.
Old May 6, 2007 | 09:57 AM
frty7ford's Avatar
frty7ford
ok so what is the fix?
Old May 6, 2007 | 11:19 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You need a distributor for an FE engine. All the FE dizzys interchange. The last year for points was 1973. The oil pump shafts (B8AZ-6A618-A) fit all the FE's from 1958/76, and the 330 FT engine from 1964 and up. The oil pump shafts are different for the FT 361/391 (C4TZ-6A618-A). There was a dual point dizzy also: C0AZ-12127-E. These were standard equipment on HiPo 352's (1960/61) 390's (1961-63), 406's and 427's, but fit the 352/360/410 and 428's.
Old May 6, 2007 | 11:30 AM
frty7ford's Avatar
frty7ford
how can i tell if the 390 is a 391 ft or not I would think that the dist from the 352 would fit. I wish i had gotten more info off the donner tow truck I got the engine out of.
Old May 6, 2007 | 11:37 AM
arctic y block's Avatar
arctic y block
Why can't ya drop the pan and swap in the matching parts from the 352?
Old May 6, 2007 | 12:29 PM
NumberDummy
Look along the base of the dizzy, just below where the rim of the cap sits.
There's a STAMPED Ford dizzy number there...similar to: C5TA-12127-AA. Find the number and post it here.
Old May 6, 2007 | 12:30 PM
frty7ford's Avatar
frty7ford
I cant get the distributor to drop far enough into the block to engage the oil pump drive. I am thinking I might have to find an after market ignition that will take the dura spark dist that fits. this is just strange every thing mic out the same untill I get Just below the drive gear then the 390 is smaller from
Old May 6, 2007 | 12:32 PM
frty7ford's Avatar
frty7ford
d5te 12127 pa 5g1
Old May 6, 2007 | 12:34 PM
arctic y block
Sometimes if ya just bump the starter or turn the engine by hand it will line up with the shaft and drop right in.
Old May 6, 2007 | 12:37 PM
frty7ford's Avatar
frty7ford
that only works if the dist will engage the cam and this one will not drop in far enough for that. the hole in the bottom of the block seems to be to small
