97 eddie bauer
Old May 5, 2007 | 11:38 AM
Rufusr's Avatar
Rufusr
Unhappy 97 eddie bauer
1997 Explorer, Eddie Bauer AWD, V-8 5.0 liter, Automatic, 130,000 miles.
Tires, rotors, and brakes all good<O</O
<O</O
I am having a problem with a vibration in the front end as I let off the gas at 60-70 miles per hour. The problem started after my front driveshaft CV joint failed. I replaced the front driveshaft and felt the vibration. I removed the replacement driveshaft and found the CV boot was broke. I returned it to the parts store were they were glad to give me a replacement driveshaft. Although after replacing the driveshaft again I still have the vibration. I have replaced the rear U-joints also just to make sure the vibration was not in the rear. Any help would be appreciated.<O</O
Old May 5, 2007 | 11:45 AM
aquanaut20's Avatar
aquanaut20
Rule of thumb, if you feel it in your seat it is from the back, if you feel it in your feet or hands it is the front,
You obviously have something out of balance, alignment or loose.
