my 76 keeps dieing
Old 05-05-2007, 10:54 AM
BIG-COUNTRY's Avatar
BIG-COUNTRY
BIG-COUNTRY is offline
Cool my 76 keeps dieing
i got a 76 with a 302 and it idels fine in park but if i put it in any other gear it starts to die like its out of gas. does anyone know what would cause this??
Old 05-05-2007, 11:04 AM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Vacuum system leaks ?
Old 05-05-2007, 11:30 AM
dantrade4's Avatar
dantrade4
dantrade4 is offline
sounds like you are too lean could be vacume leak or carb needs rebuild. Does it idle at correct rpm and smooth when in nutral? If it idles rough check EGR may be stuck open usualy causes rough idle.
Old 05-05-2007, 11:37 AM
dantrade4's Avatar
dantrade4
76 dieing
Check for vacume leaks and EGR stuck open but this should make it run rough at idle or elevated RPM. you are too lean for sure carb may need rebuild if it is 2150 motorcraft they are very easy to rebuild and kit is cheep.
Old 05-05-2007, 12:25 PM
pfogle's Avatar
pfogle
pfogle is offline
Double check your wires. They may be on in the wrong order.
Old 05-05-2007, 01:09 PM
BIG-COUNTRY
thanks guys ill check it out and get back with ya
Old 05-05-2007, 02:35 PM
BIG-COUNTRY
well i have no vacum leaks and i put a new egr on and it still does it the carb is a holly 4barrel and it looks to be new. i ideled it up to were it would stay crunk in nutral but its blowin white smoke out my exhaust (runing rich)and it still shuts of when in drive or reverse
Old 05-05-2007, 03:26 PM
m78's Avatar
m78
m78 is offline
white smoke is usually water. like a head gasket leaking
Old 05-05-2007, 03:55 PM
BIG-COUNTRY
come to think of it i did just replace the thermastate /water outlet gasket cause it was leaking pretty bad. could that be my problem? water in the motor?
Old 05-05-2007, 04:10 PM
m78's Avatar
m78
m78 is offline
its been along time since ive been in one of these motors but idont think the therm or riser outlet is connected in any way to put water in the combustion chamber like a blown head gasket could. you might wait till one of these other guys gets on here to answer that, they are extremely knoledgable about this stuff. is that spelled right?
MJ76
02-13-2014 10:55 AM
00RANGER/76F250
03-26-2008 10:40 AM
Watry
10-17-2007 03:37 AM
rebelsouth76
1999 to 2016 Super Duty
06-17-2007 09:07 PM
1979 Ford
18
03-27-2006 07:56 AM
Quick Reply: my 76 keeps dieing
