TPS sensor?
Old May 4, 2007 | 11:59 PM
Jrock909's Avatar
Jrock909
TPS sensor?
Is it possible to have a bad TPS sensor even if everything checks out?
Old May 5, 2007 | 01:41 AM
StealthWyvern's Avatar
StealthWyvern
What makes you think that its the TPS? What is your truck doing?
Old May 5, 2007 | 04:24 AM
92F150Flare's Avatar
92F150Flare
I think it's just a variable resistor and if the voltages check ok....it has to be ok. At least that's what I'm learning..lol.
You could have a bad lead or plug from it maybe......not getting the voltages where they are supposed to be. It's part of a circuit and has to go somewhere.
Old May 5, 2007 | 07:06 AM
eric f150's Avatar
eric f150
whats the truck do??
Old May 5, 2007 | 10:55 PM
Jrock909's Avatar
Jrock909
Surging idle at when the truck is warmed up, I just can't figure it out...
Old May 6, 2007 | 04:19 AM
92F150Flare
IAC?........Cleaned or replaced and many talk about cleaning the TB also......might help some.
Small Vacuum leak might cause it too....
Good Luck
